does the muffler determine what size engine it's used for
I'm a little confused. How does the muffler on two completely identical systems make a difference on what size engine it gets used for. You have the same exact head pipes but one is a megaphone muffler and the other is not. How does the not megaphone get used for engines that are bigger than 117". I would think you could use them both on the same engine.
Received 4,614 Likes
Not really sure what you mean, identical systems, but different size engines; you mean identical head pipes?
Megaphone is kind of a style; you can match a megaphone style to probably any Harley engine. The internal diameters and baffle and/or sound reducing materials determine more than the outside appearance. The bigger or higher performance engines will want interior construction that will allow higher air flow, whether they're megaphone (big rear end styles) or slimmer looking straight shots. I haven't checked mufflers for engines 117 or larger, could be nobody makes a megaphone style for them - but they could if they wanted to. You could probably find one that fit the header pipe diameter and mounting brackets for your bike, but if it wasn't rated for your larger engine, the internals might not pass enough air to reach the engine's potential performance.
What I was referring to was the bassani road rage II b1 vs the megapower. From what bassani says and the web site also reflects is the only difference between the 2 is the muffler. But yet lots of people say the b1 is only for big bore engines. I'm not sure what the muffler bearings are or if it will make that big of a difference. The pipes themselves are the same. I'm buying a set of the b1 and just want to know what I'm getting into. I think I'll be fine but want to know what others think.
