06 Dyna, is a clutch puller tool needed?
05-10-2015, 08:19 AM
Trying to remove the inner primary on 06 Dyna, do I require a puller to get the clutch removed?
Thanks in advance.
05-10-2015, 08:40 AM
No, but watch out for the clutch hub nut...it is left hand thread!
05-10-2015, 01:39 PM
I highly recommend a shop manual for doing this kind of job.
05-10-2015, 06:30 PM
You will need to make a clutch locking rod to remove the clutch nut and to torque it back.
05-10-2015, 07:24 PM
all of the above are correct but I especially recommend nevil's suggestion to the service manual. Almost every job you ever do on your harley is described perfectly in that book.
05-10-2015, 09:44 PM
the clutch is on splines, not on a taper shaft so will slide right off, as the others said a service manual is invaluable if you do your own work.
hell hound
10-20-2012 06:52 AM
128auto
06-12-2012 03:09 PM
Jinxie
07-29-2009 11:32 PM
0311usmc
13
03-27-2009 07:42 PM
labfreak
06-29-2008 06:30 PM
