after market speedo installation help
I have a 2006 super glide. Bike came with no speedo. Purchased aftermarket unit and attempting to install. I cannot seem to determine how to adapt speedo to oem wiring. The instructions that came with the new unit does not seem to match the color scheme of wires on my dyna. Can someone please assist me with this?
Thanks for everyone's time
I color coded the diagram for you, this should be correct, but not knowing your exact speedo I cannot be positive.
For 2004+ Harley
The tachometer signal (GREEN wire on your new speedo) will come from the negative side of the ignition coil. Blue/Orange for the front cylinder, Yellow/Blue for the rear cylinder, connect the tachometer input to only one of these two wires.
http://www.hdcustomfab.com/ebay/speedo.jpg
Hope this helps.
For 2004+ Harley
Hope this helps.
I purchased a VT No: 39-0599 speedometer
http://www.vtwinmfg.com/webapp/wcs/s...102_3311980_-1
thanks for you time and quick response
Jason Bradford
11-01-2012 05:38 PM
