Losing Transmission oil into the primary
Would think it's the inner o-ring seal on the clutch push rod. There are 4 seals between transmission and primary. The primary vents to the transmission, so I have yet to figure exactly this seal works. Make sure you are not overfilling transmission. It usually comes from the engine seal at the front. Primary is full of metal and rough on seals. It would have to be coming from the small hole in post one of this thread. https://www.hdforums.com/forum/evo-c...-question.html
walkalone
06-25-2013 12:59 PM
