Question about installing drag bars
Old 05-19-2015, 09:33 PM
wolvie1892's Avatar
wolvie1892
wolvie1892 is offline
Default Question about installing drag bars
Hello everyone. I am installing 1.25in 10inch tall drag bars on my 2014 dyna street bob. I was wondering if anyone had any advice on the best bolts and bushings to use to install them. I've only installed handlebars with risers so this will be a new experience and any advice would be greatly appreciated.
Old 05-19-2015, 09:49 PM
HD Bobber's Avatar
HD Bobber
HD Bobber is offline
Buy a set of Gooden Tight riser bushings for around $50. They stiffen things up a bit and clean the bottom bolt area up by being flush.
Old 05-19-2015, 09:53 PM
wolvie1892's Avatar
wolvie1892
Thanks bobber. I'll look those up.
Old 05-19-2015, 10:30 PM
robbyville's Avatar
robbyville
robbyville is offline
I just re-used my stock equip. Pretty easy job. Good luck and have fun! If you need any tips or such search my threads for the bar install.
Old 05-19-2015, 10:34 PM
wolvie1892's Avatar
wolvie1892
Thanks for the info
Old 05-19-2015, 10:38 PM
HD Bobber's Avatar
HD Bobber
Yah the new bikes w/ the redone wiring are SIMPLE compared to mine, which I had to depin an array of rainbow amounts of colored wires. Should go real smooth and you probably won't have to depin anything as your connectors are tiny.
For sure check those bushings out.....nice cheap upgrade.
Good Luck
Old 05-19-2015, 10:41 PM
wolvie1892's Avatar
wolvie1892
Good Luck
Yeah the size of those connectors are the only reason I'm gonna tackle the internal wiring myself. Should be simple, I hope.
Old 05-20-2015, 06:21 AM
robbyville's Avatar
robbyville
It really is so long as you have a good leader for your wiring (think string with a nut on the end), whole job would have taken me a couple of hours if I hadn't made it harder on myself and had to learn throttle adjustment. Link on page 3 I think of the thread below. One of the most worthwhile home mods because it saves so much money in labor.
https://www.hdforums.com/forum/dyna-...odel-bike.html
Old 05-20-2015, 06:24 AM
tfalcon's Avatar
tfalcon
tfalcon is offline
I used the cheapest poly bushings I could find off of phatperformance, I think they were like 8 bucks and work perfect.
Old 05-20-2015, 07:44 AM
wolvie1892's Avatar
wolvie1892
thanks for all the info guys, I am going to tackle those bars thursday morning after work and see what kind of trouble I can get into.
Quick Reply: Question about installing drag bars
