190/60R 17 Avon Cobra on 2013 Street Bob
Old 05-23-2015, 04:37 PM
jeepnjarhed's Avatar
jeepnjarhed
jeepnjarhed is offline
6th Gear
Default 190/60R 17 Avon Cobra on 2013 Street Bob
Just installed this size (and a 110 on the front) with no problems. The rim is a Harley Reaper but is a stock size (4.5). The bike already had a quick detach mount set up on it which includes the low profile inner wire brackets so I didn't need a wide tire kit. The installer said he had no problems mounting it and there is no clearance issues. The handling is ALOT better but the ride is a little harder feeling.
Old 05-23-2015, 09:37 PM
lh4x4's Avatar
lh4x4
lh4x4 is offline
Glad you posted this. I have been trying to figure out the biggest tire for the back. That is a sharp bike. Like the seat and exhaust. It all looks right.
My current set up for the 13 Street Bob is the stock size and spoked wheel. It does not go will with my set up.
120R
Old 05-23-2015, 09:59 PM
Nitro 54's Avatar
Nitro 54
Nitro 54 is offline
Looks nice !!!!! Can you measure the width of the tire sidewall mounted for me? I want to compare the width with the 180 Night dragon to see if this might be another tire option if the Pirelli doesn't last long enough.
Old 05-24-2015, 12:59 AM
BigDogIdaho's Avatar
BigDogIdaho
BigDogIdaho is offline
There is also at least one person here who is running a 200 on his SB.
I know I'm definitely going wide when it is time to replace my rear.
Old 05-24-2015, 01:33 AM
jeepnjarhed
6th Gear
Thank you, your bike is pretty sweet also!
Old 05-24-2015, 01:35 AM
jeepnjarhed
6th Gear
I will attempt to measure it in the morning, not sure how accurate it will be...
Old 05-24-2015, 01:43 AM
jeepnjarhed
6th Gear
A 200 would be really tight, I thought about it but the max recommended for Harley rim (4.5") is 180 so I didn't want to push it much more... I do believe the posts I saw for a 200 tire involved a wider rim (at the least) and a prayer! the guy who installed my tire said I had abut 4-5mm clearance on either side, if you do the math that would put a 200 WAY to tight for my comfort...
Old 05-24-2015, 08:03 AM
arkstreetbob's Avatar
arkstreetbob
arkstreetbob is offline
I have been running the Avon Cobra 190 for a while. Getting close to 5000 miles and it still has a lot of miles left on it. Great tire. It is on stock HD spoke wheel.
Old 05-24-2015, 08:07 AM
Odin510's Avatar
Odin510
Odin510 is offline
Can u take a pic under the fender where the turnsignals connects? I'm curious to see what yours looks like there.
Old 05-24-2015, 01:23 PM
jeepnjarhed
6th Gear
Hard to get it lit up, looks closer than it really is due to slight angle of camera...
Quick Reply: 190/60R 17 Avon Cobra on 2013 Street Bob
