driveline noise
Old 06-07-2015, 06:45 PM
jackie fred's Avatar
jackie fred
jackie fred is offline
Stage III
Default driveline noise
11 Super Glide Custom 13000 miles---Recently I have noticed a noise that sounds as if it is coming from the primary case. This noise(rattle) shows up at about 60 in 6th gear. I know that 60 mph is on the low side to engage 6th but it can also show up in 5th when the engine is in the lower rpm. I try not to lug the engine but it does make the noise at light cruse.(only on a hot engine)
Any ideas would help,
Thanks, Jackie
Old 06-07-2015, 10:50 PM
8541hog's Avatar
8541hog
8541hog is offline
You pretty much answered your own question. Stop lugging the motor. I don't even hit 5th until 55. You say you try not to lug it, but you are.
If you were to take the time to check it out, you would find you are also losing efficiency in your MPG. You should be cruising in the 2500 - 3000 RPM range for best efficiency of the motor. I would also guess that the bike will ride smoother in that range as well.
Old 06-07-2015, 11:42 PM
rjo3491's Avatar
rjo3491
rjo3491 is offline
I never engage sixth gear below 70 mph. In fact, my bike seems happier in fifth at that speed. Am I doing any damage (besides perhaps fuel economy) by not upshifting?
Old 06-08-2015, 12:54 AM
bdtaylor1979's Avatar
bdtaylor1979
bdtaylor1979 is offline
Also, if you are using lower octane fuel you might be getting spark knock.
roussfam
09-17-2015 04:35 PM
cmancini26
07-21-2012 11:38 AM
radudel
Exhaust System Topics
13
06-20-2012 04:24 PM
BlatBlatPow
07-29-2010 04:36 AM
Stumpman
05-14-2006 11:43 PM
Quick Reply: driveline noise
