Problems Starting
Problems Starting
So I have had this starting issue for some time now, it would start just fine when cold, but would give out like a grinding noise if i started when hot.
I looked it up and lot of people are saying either compensator or the starter clutch..Does anyone have any input on this?
Also this happened for the first time today, I put the key to "Ignition", put the bike on "Run" but when I press "Start"...nothing.
The bike has good battery so its not that, it almost feels like the starter isnt even there, not a click let alone a crank..any ideas what this might be? (this one happened this morning when the bike was cold)
You say the battery is good, unless you had it load tested you can't tell just by the standing voltage. Look at the terminals at the battery and ground cable, clean them up if needed and make sure they're tight.
It could be the starter clutch but I would first look at the starter relay. See if the tabs are clean and make good contact. Those are generic and cheap, you can get a new one at an auto parts store and see if it works.
not sure on the grinding on warm. i used to have that happen once in a while on my 08. my negative terminal was a bit fried. finally got a new battery and it hasn't happened since. these bikes draw a TON of power when starting. if you don't have a perfect connection it'll cause all sorts of screw ups.
as for the starter not doing anything, was the bike in neutral? ive swapped my bars a ton, and eventually noticed that depending on install, sometimes i can start the bike in gear with the clutch pulled in, sometimes it's got to be in neutral. i'm not sure which way the factory intended, but i know there's a small switch in the pod someplace that causes this. if you're attempting to start with the bike in gear and getting nothing, i'll bet that's your issue. as a side note, if you install a push starter right on your starter ($11 part) that will always start the bike with the clutch pulled in. it's a nice back up just in case anything ever goes haywire in your pod.
