Which cams???
Old 06-18-2015, 06:35 PM
wwillen's Avatar
wwillen
wwillen is offline
Default Which cams???
I'm planning a custom build on my 2013 FXDWG to include SE Pro Max Velocity Area cylinder heads, SE pro high flow injectors (6.2 grams/sec), SE Pro high flow 58mm throttle body with the intake mani, and the SE heavy breather for a 58mm TB. Can I use SE-259E cams with a build like this? Thanks.
Old 06-18-2015, 06:53 PM
slyedog's Avatar
slyedog
slyedog is offline
Way too much throttle body and injector not needed either. Bore you stock one to 48 and get the stock heads reworked. If you are going to a huge big bore then maybe a 52 would be justified. All can be port matched and then add a .030 head gasket to bump compression a tad. The big thing is where you want the power and how you ride. Sorry to burst your bubble but you plan to spend a lot of money in the wrong direction without more cubes and the stock heads reworked are way better than the screaming eagle will be.
Old 06-18-2015, 07:33 PM
wwillen's Avatar
wwillen
wwillen is offline
Where can you get the TB bored? Would I still send the head to SE to get worked at port matched to 48mm? Also I'm assuming there will be no need for high flow injectors period? Which cams in this case would be better then?
Old 06-18-2015, 07:44 PM
target64's Avatar
target64
target64 is offline
I just built a 103 with Andrews 57 cams with hillside's stage II heads along with a pro 50mm screaming eagle TB which comes with the 4.9 injectors and it runs very well
Old 06-18-2015, 08:01 PM
wwillen's Avatar
wwillen
wwillen is offline
Did you need to buy different pistons?
Old 06-18-2015, 08:20 PM
target64's Avatar
target64
target64 is offline
No stock pistons compression set for 10.1
Old 06-18-2015, 09:03 PM
wwillen's Avatar
wwillen
wwillen is offline
Stock compression for my rig is 9.6:1. Do I need to get it to 10:1
Old 06-18-2015, 09:07 PM
HD Bobber's Avatar
HD Bobber
HD Bobber is offline
Way overkill on TB and injector. Get an SE 50mm which will come w/ 4.9 injectors which will be plenty! You can see my build below and its w/ stock injectors.
As for the heads I would send'em out to a shop of choice to rework them for your build. They will also tell you exact can to get to meet the head work.
Old 06-22-2015, 11:34 AM
Redbeard's Avatar
Redbeard
Redbeard is offline
Check with Hillside Cycle, a sponsor here, for a combo of parts that will work together to meet your desired results.
Old 06-22-2015, 12:03 PM
HD Pilot's Avatar
HD Pilot
HD Pilot is offline
Living in the state of Washington, here is a great source for throttle body boring and headwork: http://baisley.com/index.htm
Like others have said, better bang for the buck can be had...
RK14SGS
2014-2023 Touring Models
13
01-19-2015 05:06 PM
Shirkey
Exhaust System Topics
06-01-2012 09:59 AM
N-gin
43
04-05-2011 06:34 PM
GAstreetglide
25
11-26-2008 08:21 AM
Fast FLHX
09-14-2008 12:05 PM
Quick Reply: Which cams???
