Rear signal relocation kit issue
I bought a cavalry customs plate bracket, which is pretty identical to the great bike gear bracket. Nicely made, however I don't see how the hell you mount the plate, once the bracket and signals are installed. You need to use nuts and bolts to hold the license plate, and once mounted to the fender, there's no way in hell in getting my fingers behind it to hold the nuts. I'm completely lost here... If only it used threaded holes instead of nuts and bolts, it would be perfect. Check it out:
No way I'm getting my fingers or a wrench under there to hold the nuts.
Has anyone used one of these? I must be a moron because I see no way to do it...
Disregard the post. It's going back and I'll find a better bracket.
Thanks, I thought of that, only its a nylock and will likely spin out of any glue when it starts to grip. It's just a bad design. Simply threading the holes would be a much better solution I would think.
