Front turn signal relocation
Old 06-21-2015, 11:32 PM
Schwanz583's Avatar
Schwanz583
Schwanz583 is offline
Default Front turn signal relocation
Has anyone with he newer model fxdb (where signal wires are direct into switch housing) done a relocation and installed led blinkers? I'm wanting to do joker machine and they say I'll need a intensifier and a module that expensive as hell to keep my 2013 from throwing codes. Also, do you have to buy new wire to hook the signals up since you cut the original al ones? (Mine has no signals at all right now) I looked at the harley instructions on their relocation kit and it doesn't show where the new wire comes from or where it connects. Thanks guys, just hoping someone has done it, and bonus if someone has mounted LED's so I know what I'm getting into!!!!!
Old 06-22-2015, 05:35 AM
Mchad's Avatar
Mchad
Mchad is offline
Received 3,510 Likes on 2,133 Posts
On the canbus bikes there are connectors on the harness in the neck of the bike for the relocated signals. The Harley key comes with new reflectors/wires/connectors to replace the one you cut off the bars. If you get aftermarket signals you'll need the reflector kit from Harley. Or to fabricate something.
streetbob87
09-05-2014 11:10 AM
Dyna7
07-14-2013 10:48 PM
saschagast
07-06-2013 08:54 PM
snakeyes
05-15-2011 06:59 PM
dietzy
07-17-2007 08:23 PM
Quick Reply: Front turn signal relocation
