K-Tech Suspensions, anyone heard of or used this?
I am looking for a shock with a close radius housing and ends, some springs cause interferance issues with my setup. I like the look of the Bullit they offer. I notice them via the new Hot Bike mag. Just wondering if any one has heard of them, any pros or cons known of? Yes, they are pricey too.
http://www.k-tech.uk.com/
http://www.ktechsuspension.com/
http://www.orientexpress.com/p-20413...ar-shocks.aspx
K-Tech Suspensions
K-Tech Suspensions has been around for a little while while now doing cartridges for race bikes. This technology comes from motorcross bikes and runs on air pressure. With some out of the box thinking, those shocks can be made adjustable adding an air ressy tank and a very stout compressor. They were designed for front forks.
I looked very hard into developing something like this system but the reality soon crept in after a few minutes. You think the Airnot system is bad if you chafe an airline or the bag breaks and will not hold air. You are in the motel until UPS delivers a new airline or maybe a shock or two. When these leak and I say when and not if, if you are on a course, no problem, your crew comes and gets you. Try that in places you may travel to while touring. A long way to get another one. That is why I did not consider a KYB PSF (Pneumatic Spring) with air-adjustable spring rate. The shocks in question are sealed nitrogen and non-air adjustable (no compression/rebound/spring adjustable from the handlebars) but if the seal head leaks and (a nitrogen molecule is much smaller than an oil molecule) leaks out than just think on that for a while. Yes, I was dreaming that you could control compression & rebound also if so designed on your bagger. Very tempting however, think about being on I-92 in the middle of S. Dakota at 1am traveling across country or even worse, a really desolate place we all can relate to.
And that is why I would not do it. Coil overs will always get you home, air controlled, you get the idea?
TxFxL (08-14-2017)
We have one Harley out there with the bullit shock. We did have to increase air pressure over the stock pressure to get the bike to feel like it wasn't riding on the bump stop. As far as long term durability I don't know. I'd like to think they have it figured out but only miles will tell.
I'm with Howard with the affinity to springs. If a seal fails you can ride the spring home.. If the seal fails on the bullit shock you ride the bump stop home. Close to riding a hard tail. They do seem like a really nice solution for tight areas.
On my bike I went back and forth between put a set of ohlins and a set of ktech razor line shocks. I chose ohlins because of the hydraulic preload option which was key to my happiness for easy spring adjustment for solo and two up riding.
@slyedog: "I'll have to double check their catalog on the black. Called them a while back and they said only chrome in covered option. Do you remember the part number?"
I recall I had to hunt around a bit for them too. Not very popular apparently, though I love mine.
Part Number for mine (12") is 412-4042B
Here's a pair on . I think I got mine from Motorcycle Superstore, but can't recall for sure (three or four years ago)...
I have also been looking at the Hagon classics because the springs at the top and the lower is narrow.
I currently run the Burly Slammers which don't have any issues. I installed the stock shocks and the wide cup at the bottom of the shock was hitting my bag durning compression, so the bottom of the shock needs to be narrow much like the Burly's.
I want to go back to a taller 12-13 shock that has the clearance issues solved for me.
