New Cams, bike wont start
#61
The theory/reason behind aligning the oil pump after installing the cam support plate is that the cam support plate is not guaranteed to be reinstalled exactly as it was before. There is a fair amount of "slop" whenever you reinstall just about any part that has multiple fasteners - for instance the rocker covers, need to take some time to make sure they are "square" before torquing.
So back to the oil pump, the oil pump needs to be aligned with the crank shaft, NOT the cam support plate. This is why a lot of the mechs that do this for a living always align the pump per the SM after removing the cam support plate.
Now I know the S&S cam install video leaves the pump attached - have no explanation why but it seems logical to me to align the oil pump as per the SM Instructions.
#62
When I was doing my research before my cam swap, I read that the oil pump alignment was more of a TC88 issue and even the alignment tool listings all pointed to the 88. Of course, the S&S vid and even the Fuel Moto vid make no mention of aligning the pump so I followed those and luckily had no issues. When I go with a bigger motor, I will align it then.
#63
Having to try to line up two separate gerotors pumps to the crankshaft land while also trying to not **** or pinch the yellow oil pump o-ring while lining up two camshafts into two Torrington bearings....... is the primary reason to remove the cam plate separately from the oil pump.
Honestly I never heard of doing it this way, but I have read recently of fragmented oil pumps.... here at HDForums as well as HTT by people who have attempted to do a cam change leaving the oil pump on the cam plate.
I haven't heard of a instant oil pump failure doing it the other way.
I do a lot of cam changes, and just cant wrap my head around why one would want to not only view the oil pump internal condition (scoring against the cam plate) but also risk misalignment with the crank, or cutting the vital oil pump o-ring.
#64
Maybe you should call S&S and complain about their instructions?
#65
#66
#67
I did check the sprocket alignment and was within tolerance. I couldn't honestly tell you why I was unlucky enough for this to happen. I can tell you though that the first thing the HD mechanic asked me when I dropped off my bike and explained what I was experiencing was "did you re-align the oil pump" , to which I replied....sunuvabiatch, didn't know about that!
Sounds like something that although may not totally be necessary, is probably good practice to do. If I ever decide to upgrade again, I will definitely perform this extra step.
