Tapping noise on 2009 dyna
Old 08-02-2015, 03:18 PM
92-yotaboy's Avatar
92-yotaboy
92-yotaboy is offline
Default Tapping noise on 2009 dyna
I've got a question. I have a 2009 Dyna low rider with 12k on the clock. I'm getting a inconsistent ticking noise (clutch in/ out, warmed up/ cold, moving/ sitting but it's also off and on). All I can tell is its coming from the power side of the engine right around where the cams are. For what it matters, I had a set of 574 reaper cams installed about 1,000 miles ago. But the ticking noise just started about 300 miles ago. I have no clue what it might be any suggestions?
Old 08-02-2015, 03:37 PM
Lama's Avatar
Lama
Lama is offline
If you reused the stock tappets / lifters it is most likely the cause. The stock lifters are prone to collapse failures.
You most likely have adjustable pushrods so that may be another source, a jam nut backing off the pushrod , but they usually unscrew themselves completely causing a huge noise and rough running.
The fact it comes and goes sounds more like lifter.
Change your oil, put in some standard (non synthetic) 20/50 and try again, if that quiets it somewhat especially when cold then it most likely is a lifter.
Old 08-02-2015, 04:29 PM
92-yotaboy's Avatar
92-yotaboy
I did reuse the stock lifter/ tappets with SE adjustable pushrods. Do you think that I'm ok to keep riding the bike or should I park it until I get some time and money to find out what's causing the tapping? Won't using standard oil after using synthetic gum up the oil passages in the engine?
Old 08-02-2015, 04:56 PM
Lama's Avatar
Lama
Lama is offline
Ok
Your call
No
BigMESA
10-26-2013 08:08 PM
NECaveman
12-02-2012 03:37 AM
rwtrick
07-02-2011 03:20 PM
sparky_mo
11-29-2010 07:35 AM
97classic
EVO
07-14-2009 02:17 PM
Quick Reply: Tapping noise on 2009 dyna
