2015 Street Bob - Quick Detach Kit & Side License Plate
It's late and I'm tired of searching and reading. On my (new) 2015 Street Bob, will I need to move the license plate if I get the quick detach kit so I can use a removable sissy bar? Based on what I've read so far I'm still not sure if I need to move the license plate (currently side mounted to left turn signal) and/or the turn signals too.
Thanks for the help.
Using the Harley stuff yes. Had to do it with mine.
Started with this
Ended with this
The harley kit has you cutting and splicing 6 wires for the turn signals. Kind of the lazy mans way out. I ended up picking the connectors and rewiring them after I ran the wires through the new mounts. The plate relo kit was a nice easy plug and play.
Started with this
Ended with this
Great info - thanks everybody. Funny - I had a 2007 Street Bob - and I'm essentially working on making this 2015 the same/similar - but some of these "new improvements" to the bike are causing me some issues (ie - the front turn signal relocation isn't as easy as it was then from what I'm reading so I have to figure out the best way to tackle that too!).
The pics helped a lot. Thanks for the offer Suede, but I'm not ready to pull the trigger yet. I'm a bit cash poor at the moment and will be chipping away at the customizations - but I'm making my "to-do" list right now.
I actually may go this route for the relocation of the plates & lights I think; seems to be a little more "low-profile" compared to the HD setup: http://www.greatbikegear.com/index.p...ate-frame.html
So I'm doing a little thinking here...
If I went with the HD quick detach kit - will my turn signals mount up with it no problem? Or will I need to buy or make a spacer of some sort to use them?
I'm thinking that if that's possible, that I can then pick up a lay down license plate mount that has a frame with LED light in it and just slap it on the fender (drill some holes).
My 07 Street Bob had that type of license plate - but there was more fender there too. I think I can fit a lay down mount, use the existing side mount light wiring and be good. I just dont know what, if anything, I have to do regarding the stock turn signals. I want them as close to the fender as possible too (think I remember a way to move them closer, even with the quick detach kit installed, no?).
