Damn Starter
Damn Starter
Well, haven't been able to ride for almost a month due to work, weather and a few medical issues, finally last night, backed the bike out of the trailer and when I hit the starter I heard the most awful grind I have every heard, almost sounded like the damn starter blew apart, metal on metal grind. Just wasn't meant to be I guess, off to the shop in the morning.
Dropped it off, it was still making the same noise. Mechanic said it sounds like the starter, possible just the starter clutch. He noticed something I did not notice and that is the engine light and speedo light were not coming on when the key was turned or fuel pump engaged, he said probably "not" likely but could be the battery voltage? going to check that first. I will post the final findings.
Well, the news hasn't been good. The mechanic called today, he said the starter and the clutch basket ring gear are both missing several teeth, he said it looks like one of them froze up causing them to basically break up. He said he has never seen anything like it. So far it looks like a new starter and ring gear. I am having the inner primary powdered while it is off so I guess that is the up side if there is one.
