How to ID FXDWG vs. FXDF triple trees
Isn't this YOUR photo of YOUR trees...yes?
Because of the pinch bolt location (and some other things), they appear to be some original 49mm FXDWG trees, like maybe 2006-07.
To confirm that you have a set of raked Wide Glide Trees installed, point your forks straight ahead, then look from the side at the tube and neck relationship. If the gap is wider (larger) at the bottom than at the top (not parallel), then of course they're raked (see FXDWG photo below)
It's also easy to detect if there any rake in a set of bare trees without tubes, just slide that top tree down on top of the bottom...do the tube holes line up?...yes, no rake. If they don't line up...they are raked.
Btw FXDF Trees have a slight NEGATIVE rake...they're not 0° (at least, not the ones i've had or looked at)
Wouldn't you be able to tell just by looking at the angle of the fork leg cap compared to the top tree. I do belive the forks on a wide glide tree would have the cap pitched back (3 degrees rake) and a fat bob tree would be parallel to the cap (zero rake) (this is how they look on my fat bob trees).
I thought the method i used was easier to explain, illustrate, and be detected by someone unfamiliar with the process.
Now let me plant the seed with you that the Fat Bob trees have a Negative Rake. Now if you're open to that, look again at your FB Trees from the side and/or top...can you see it?
I noticed it originally while looking at a FatBob at the dealer, then confirmed it after getting a set of trees.
Here's a couple threads i just grabbed in a search where the OPs were questioning the 0° Rake. In the second link the Op didn't realize he had FB Trees until later.
https://www.hdforums.com/forum/dyna-...rees-rake.html
https://www.hdforums.com/forum/dyna-...tood-help.html
First suggestion is to start your own thread and not try to hijack someone else's... that's just rude dude.
Also sporting the FatKid fender for fatbob... good price and the fender is pretty sound... some hole modification may need to be had... I did a little as I was mounting up to wideglide fork sliders.
