Strange problems after dyne tune
Strange problems after dyno tune
So I fells for the suckers bet of dyno tuning my bike with Stage I upgrades. My current setup is a 2015 FXDL w/ SE stage I intake and V&H Big Shots Staggered exhaust. I had been running an FP3 with this setup since I installed the mods. I just recently decided to pick up a SEPST and have it dyno'd by my dealer. The bike seemed to run smoothly when I picked it up, the only thing that concerned me was that my AFR curve was dialed right between 14-15:1. My initial pull showed between 13-14:1 w/ the FP3 map.
About three hours after I got the bike home I left to go run some errands and noticed the check engine light had come on. I thought hey no problem, I'll plug my FP3 back in to read the codes. So I got it plugged in and read the code, but thought it was strange that the FP3 thought my canned map was still the one that was installed on the ecm even though it was not. I unplugged the FP3 and started the bike. Started up fine but idled at 2000 rpm, much higher than normal. I decided to ride back to the dealer to check it out, and noticed the turn signals no longer auto canceled anymore, the speedo did not work below 50 mph, the gear indicator did not know what gear the bike was in, and the bike was running like crap. It seemed like it was running super lean, really rough and lots of engine heat. My exhaust is now a beautiful bright metallic blue (under the heat shields).
The bike now sits at the dealer for them to troubleshoot and fix. I hope I didn't cause the problem by plugging my FP3 back in to read the code. I probably should have just left it alone and waited until I do cams to put it on the dyno.
I'm curious how it will pan out. I just bought the FP3 and was planning on using that instead of the SE tuner that I also bought with the bike. The dealer is supposed to do the SE tuner and dyno after I hit 1k miles. Was your running better with the FP3 map or after the SE tuner map? I'm thinking of just telling them I don't want the dyno tune anymore.
So, an update on the problem.... The dealer tech ran all of the diagnostic tests called for in the electrical diagnostics manual for my problems and everything checked out fine. They called HD and got them involved in the troubleshooting. HD suggested it could be a corrupted tune file in the ECM, so the dealer reflashed the stock map with the digital tech computer and all of the problems disappeared. I'm not sure what caused the tune file to be corrupted. It could have been corrupted from the beginning when they loaded it on my bike during the dyno run or it could have happened when I plugged my fp3 in.
Bottom line, I won't let that dealer put my bike back on their dyno, and I won't plug my fp3 back into the bike. I am going to have the dealer flash the ECM to a stage I download so I can get home and I will use a PV2 from fuel moto to get a proper map loaded.
