How much oil required for oil change?
the search function wasn't very intuitive, very simple question.
Doing a quick oil change, just wondering how much do the Dyna's take (2015, street bob, 103). I never go by service manual, because not all the oil is drained.
For example my sport bikes say 3.5 liters, but in reality after a drain, I only lose about 2.5 liters only so I only need to fill it 2.5 liters. What is it for these bad boy vtwins?
(yes I know, I can just measure out how much comes out when I do it but if someone knows off hand right off the back, it can help save me some time in measuring the old oil so I can spend more time riding and just do my quick final check with just the dip stick).
thanks in advance
thanks in advance
What you might find more tricky is getting the filter out without getting oil over wiring, your front engine mount (oil can damage the rubber part) and generally making a mess. Because the filter is sideways not vertical, it doesn't drain out so when you first unscrew it oil pours everywhere.
HD sells a little spout that goes in behind it which I'm told works well. I make a disposable funnel from aluminum foil. Others use cardboard, cut-up plastic bottles etc...
Received 4,298 Likes
You obviously didn't understand my question. Service manual says 2.8 L... you never fill it up to max because there is always residual oil left in the engine hence that's why everyone has said 2.4 to .5L. Owners manual only refers to total oil capacity not what actually is required during a simple drain.
s-glide76 (03-06-2020)
