Can a fuel gauge be repaired?
I recently replaced a digital Kuryakyn fuel/volt gauge with a correct (ebay, used) analog unit for my 99. It doesn't seem to be coming down from the full mark. The tank is actually about 2/3 full. The gauge drops to empty when the ignition is turned off, so it's not stuck. The Kury gauge was on the bike when I got it and is all Ive ever used. It read fine.
Can an old analog gauge be repaired?
I agree they aren't too expensive, but I still hate the idea of spending $50 for another one. Only had this one a couple weeks!
I understood them to be inaccurate when I changed from the Kury. I can accept that. Between mileage and the reserve, I'm not too concerned about running empty on the road. I just like things to work like new. I have a lot pf vintage "stuff". Often times "works like new" is far less than acceptable by today's standards, but that's part of the charm of something like, say, and old mechanical clock in your car dash.
Yeah, I can't get my dash sundial to work properly no matter how hard I try. Everytime I change direction it changes time.
Jim Comer (04-21-2021)
Pull the gauge, pull the sending unit. Hook it back up while out of bike. Turn on ign. and run the float up and down to see if the wiper is actually making contact with the resistor. If not, VERY carefully (with pointy tweezers) tweek the wiper so it has good contact with the resistor. Now, with 3 gal in tank, put it back in the bike (bike standing straight up) and turn on the ign. And see what it reads. tweak the float till it reads half tank. That is about as close as you'll get it I believe. I fixed mine twice over the years (02) but the third time, the wiper had broken off so I said screw it and put fuel in at 150 miles on the trip meter. I priced a sending unit for $157.00 but that was a while back. I should've bought a spare when they were $50. Call me cheap, but I hate paying triple just cause it's older.
