Question about using air shocks
I am thinking of running a set of the touring bike 13" air shocks on my 07 Street Bob. Could I eliminate the plastic air lines and just put Schrader valves in each shock? Then I could just pump each shock to whatever PSI I need. If this would work, what is involved with doing it? Are the shocks threaded for this and is it as simple as just buying some valves and screwing them in?
Thanks guys... Now I need to find a good deal on some used air shocks.
Edit- Is it a good idea to go with a heavier weight oil? I read that I may need to change to 10 or 15 weight due to the different shock angle of the bikes. Also would I need to spacers or do the shocks bolt right up?
I have a set of 2013 RK airshocks that I had rebuilt by bitchen baggers and shorted to 12". Also have a Harley airshock pump. I posted them in the classified section in the spring but never had anyone interested in them. I decided that they where not the shocks for me and the wife. Only rode them for about 200 or 300 miles.
