Front brake lever causing brake light to flicker
I'm guessing that my brake light switch is bad. If i jiggle the lever up and down the brake light will flicker on and off also it happens anything above about 40 mph the wind will push the lever enough to again jiggle and activate the brake light. So that being said anybody have the part number for the brake light switch I would need on a 2014 dyna street bob.
Have you changed your levers or master cylinder at all?
Reason I ask is because I changed the levers and master cylinder on mine and had the same issue. Changed back to the stock lever and had no issues. I got the stock lever powdered but had them leave part of it taped off so that the powder would not interfere with the action on the lever.
If you've done any of those mods it's worth checking out.
Just out of curiosity did your master cylinder ever bleed off any ? I notice sometimes i see fluid bleeding out around the edges
My 2010 does this. It's the shitty cover. I just wipe it up as I wipe the bike down after a ride. Never affects brake function though.
