Turn signal question
Old 10-21-2015, 08:16 PM
rlchristensenmd's Avatar
rlchristensenmd
rlchristensenmd is offline
Default Turn signal question
I have a 2013 Fat Bob. I just relocated the front turn signals from the handlebar to the front fork. The wires are connected correctly. When I turn the ignition switch on, the turn signals light up, but when l push the turn signal control buttons, the signals won't flash. This is a CANBUS system. There must be some way to reset the controls. Can anyone tell me how to do this? Thanks.
Old 10-22-2015, 05:37 AM
rlchristensenmd
I would appreciate some help from anyone who has done this! The service manual isn't helpful. It probably involves checking and clearing codes. I'm really stuck here!!!
Old 10-22-2015, 05:46 AM
QC's Avatar
QC
QC is offline
Received 19,784 Likes on 9,863 Posts
Did you have to splice and solder wires?
Old 10-22-2015, 05:57 AM
rlchristensenmd
I did not splice and solder. I ran new wire harness from bullet lights to connectors under tank. I'm confident that wiring is good, otherwise I don't think the signal lights would come on at all. I need to somehow reset the computer.
Old 10-22-2015, 05:58 AM
kontiki's Avatar
kontiki
kontiki is offline
Received 2,279 Likes on 1,155 Posts
did you use the HD relocation kit? Reason I ask is that method (canbus) requires you to do a front turn signal auto-learn procedure.
Old 10-22-2015, 07:13 AM
rlchristensenmd
I did't use the Harley kit. I made mounting brackets using the handlebar brackets. There is an old thread on this forum explaining how to do this. The wiring is exactly the same as the Harley kit. I agree that the computer needs to be reset to recognize the new lights. I went through the procedure of flashing the hazard lights ,etc. and it didn't work. I will try this again. I think I am missing something simple! Thank you fo the advise.
Old 10-22-2015, 07:57 AM
Suede Blue Man's Avatar
Suede Blue Man
Suede Blue Man is offline
I see you mention checking for codes but I'm not clear if you did, so did you check for codes?
I did this last year and my just worked, it didn't require any resetting, I wonder also if just disconnecting the battery and reconnecting and checking them again might work.
But what do the codes say?
Old 10-22-2015, 08:31 AM
rlchristensenmd
I haven't checked for codes. I'm not sure how to do this.
Old 10-22-2015, 09:06 AM
rlchristensenmd
I cycled through the auto learn procedure a couple more times. Now, the right turn signal works, but not the left. Maybe my Fat Bob is a slow learner!
Old 10-22-2015, 09:50 AM
billib1954's Avatar
billib1954
billib1954 is offline
try, try again. didn't have any issues with mine.
Quick Reply: Turn signal question
