Play in the handlebars
I just had my bars changed on my 2007 FXDB and there is a little wiggle room ie when you hit the brakes the bars move about 1/2 inch, Is this normal the mechanic said it is due to rubber bushings ?? Sounds fishy to me. This is my first Harley and never had this with any other bike
Rubber and urethane bushings have some flex, because that's what they are meant to do. But on a standard bar setup (setting aside googaw wanabe Olympic parallel-bar apes), I'd expect the flex to be much less than 1/2 inch.
This maybe a little to much play. Try to slightly tighten up. There are rubber bushings in there to absorb vibration. Some people replace there bushings with a poly bushing to get rid of the play but then you will have more vibrations in the bars. I prefer the rubber bushings. I believe the taller the bars, you would need to have poly bushings, shorter bars... rubber is ok.
When my bike was brand new my bars moved so much that the bottom edge of the risers were hitting the tree and putting gouges in it. I replaced the crappy rubber bushings with poly bushings and it's much more sturdy. I don't understand why they don't just put poly bushings in from the factory. It even made my mirrors more usable due to less vibration which was the opposite of what I expected.
