Anyone Done Fork Seals?
I need to replace the fork seals on my '99 FXDX. Has anyone done this themselves? I have the service manual, and it looks pretty simple. I've replaced dirt bike fork seals with no problem. Also, if you have done them, do you just replace the seals or do you get the whole fork leg rebuild kit?
Received 4,928 Likes
I worked on small airplanes in a past life and I rebuilt the 39 mm front tubes on my 2001 FXD without any real issues except digging up a big socket. I did a total rebuild using OEM parts and serviced with 10W oil and new slider tube caps and a 3/4 inch pre-load. The only difficult part was getting those slider caps back on with that pre-load. That was a booger.
When I found out that MoCo does not sell rebuild kits for the front tubes and putting all the parts together in one order was expensive, I had gone to a local metric dealer to get the fork oil who swore to me that the Showa front tubes used on metrics was the same and kits he sold were the parts I needed. It wasn't and they they didn't work. They didn't seem to fit right from the get-go, and I just seemed to have fight it too hard to get it all back together. My real clue came when they both blew out about 5 miles into the second test run. I pulled it all back out and built my own kit using the expensive HD parts and it all went back together again smooth and easy and I have not had a problem since.
karlkcfi
04-01-2012 03:42 PM
81FLT
04-04-2009 01:10 PM
