Trivial Top Headlight Fairing Question
Old 12-04-2015, 07:02 PM
emerican19's Avatar
emerican19
emerican19 is offline
Default Trivial Top Headlight Fairing Question
Long rant short: I'm no fairing newb, I had a Ness and a Rifle on my 07 Sbob, currently have a JD on my 02 Defender.
I'm looking at an 02 FXDX and it has the top mount headlight with the brow. I hear these are a total PIA and it's almost making me rethink buying the bike. Is my only option for a fairing to drill the bottom triple tree and relocate with a newer version headlight bucket, OR is there any other fix that someone has figured out? Thanks!
Old 12-05-2015, 04:40 PM
JohnMn's Avatar
JohnMn
JohnMn is offline
Not a direct answer,
But I've talked to a lot of folks that have the very problem you have here, not so much about the faring but that the headlamp is a POS.
I don't know why folks won't do the fix you mention, drill the hole and add a lower mount bucket
Old 12-06-2015, 07:37 AM
majastee508's Avatar
majastee508
majastee508 is offline
which style fairing are you looking to put on?
Old 12-06-2015, 08:36 AM
hell hound's Avatar
hell hound
hell hound is offline
i put a jd on my lowrider that had a top mount headlight. I bought a bottom mount bucket of fleabay for super cheap. Most fairings i have used in the past, including this one, come with a headlight relocation bracket for bottom mount.
So really all you will have to buy is a new bucket. Drilling the tree is not too big of a deal plus if you ever go back to a top mount, they make a little chrome plug that presses into the hole.
MY 14 lowrider like i said was top mount, but the bottom tree already had the hole drilled and there was a little plug in it from the factory. i never even noticed it till i went to do the fairing work
Old 12-06-2015, 10:25 AM
emerican19's Avatar
emerican19
JD Customs
Old 12-06-2015, 06:15 PM
Lama's Avatar
Lama
Lama is offline
If you are wanting to run a TSport style fairing then the OEM TSport fairing brackets or Bung King 39mm mounts are designed to use the brow mount headlight. This you already have the preferred setup.
Medic_1989
04-11-2024 01:06 PM
Dip
06-20-2017 05:19 PM
Jackpoticorn
11-13-2014 08:31 AM
heckfrozeover
10-23-2014 12:22 PM
Mims19D
05-17-2014 02:53 AM
Quick Reply: Trivial Top Headlight Fairing Question
