'15 Streetbob Forward Controls Mod
I've got highway pegs mounted in the forward control mounts and the amount of control you have over the bike when cornering with mid controls versus having your feet up in front of you is very noticeable. Much more control over the bike with mid controls and easier to switch directions. But I can see how for some very tall and log legged people forwards can be more comfortable.
I'm gonna have to disagree.
I installed this kit on my bike in the garage. I painted the primary covers while I was in there and had it all apart but was still only down for the weekend. Without waiting for paint to dry I'm sure it can be done in a day. IIRC you will need an uncommon sized socket for the job. Otherwise being mechanically inclined it should be no problem.
The mids were too uncomfortable for me at 6'3" so I love the forwards. I could only ride about half an hour on the mids, now I ride all day.
I can't compare it to the other kits as I haven't worked with them before but I have had zero issues or horror stories with this kit. It is high quality stuff so no worries there.
So I installed my forwards today, it took me all of about 2hrs most of that time was cutting the mid controls shifter shaft. I took it for a quick spin and it feels so much better on my back and inner thighs. Getting into neutral is a little trickier but just need to get used to it I suppose. I need to get a plug for the hole but everything is good to go.
Thanks for the update jricharc. Its good the hear that it worked well and your bike is lookin good! As for finding neutral, yeah I can see how that is different now. By doing it this way we are changing the shift linkage geometry a bit. HD corrects it in the kit by providing a longer trans lever.
On page 9 of the link provided by Ricketts earlier in this thread, someone posted the instructions on how to also change out the trans lever without pulling the primary apart. here's the link again in case anyone wants to also change the trans lever.
https://www.hdforums.com/forum/dyna-...g-primary.html
I just converted my Low Rider from mids to HD forwards. I had my mechanic do it for well under 2 bills. I have had them on for almost a month and it is such a better set-up for me. I'm 5-10 and after setting my handlebars back, I found the mids just too confining. I just completed 350 miles in 3 days and I could tell a big difference. I am looking to trade the pegs out for either a Joker or a DK bike pedal type foot peg. Finding neutral is no different either and the cover blends nicely into the primary. I considered leaving the mids and doing the front pegs only, but I didn't like the business of that configuration. I definitely am glad I did the conversion!
I couldn't ride my SB for 1 hour with the mids on. Now I can go hours and go on trips. I switched to forwards as soon as the parts came in (about a week).
Just to add I did the factory kit with cutting the shaft and throwing it away. And yes the only hard part is cutting that stupid shaft. Everything else was pretty simple.
