Any value to my set of cams?
I had my 05 Dyna 88 chain cams replaced with gear cams S&S 510 set and new lifters. The old ones had 22k on them and they look good. Is there any value to them? Now that the work is done I could have waited, the pads for the chain tensioners were only worn about 1 mm, they were pitted but only about 1mm. If they are of any value what should I ask?
I doubt they have much value since they never really wear out so people really aren't looking for them, ebay would be the place to check though.. I bet you could get $20 for them, somebody would buy them just to have, They would make neat paper weights.
how do you like the gear drive? Does it make noise?
did you do you're own install?
How was your crank run out?
Taterdog
01-20-2008 04:30 PM
