New Low Rider S
#1802
#1804
they do but when I look up the part number it is for the touring Harley. I think this has to do with the fact that we are throttle by wire now. When I talk to the dealer first they say the wires won't be internal which they look like they will and then they can't tell me where the accessories hook up it to plug them in and when I looked last at the Harley sight the directions didn't seem too helpful.
#1805
Received 5,388 Likes
#1806
#1807
Sure does but when you read the installation instructions it doesn't mention anything about the wiring on the dyna models. And when I looked in the store it said it was for touring models. Again I think it will fit just no idea where the connector goes to etc
Matthew Austin (12-10-2016)
#1808
As I recall when installing my bars there was a extra connector on the tbw cable that was supposedly for heated grips, but no place on the harness for it... Fwiw
#1809
haha sweet. Thanks Harley for helping? I just don't want to spend 200 and then either it doesn't work or it causes major surgery to make it work
#1810
I also put this in the general Dyna forum.
Need help installing a Memphis Shades Gauntlet Quarter Fairing on my Low Rider S.
Basically, can't get it mounted. It appears the headlight is in the way or maybe a little too high. Did anyone else with a S and Gauntlet have to switch out to a lower headlight block?
Read thru the instructions several times and tried to mount it, but finally gave up. I did remove the stock headlight fairing and all of the mounting hardware.
I have the mounting hardware for a 16 Street Bob.
