FXDF handlebar question
I searched the forum as best I could, I know it has been talked about, but I still needed some advice. I have a 2015 FXDF, I like the looks of the stock drag bars, however I would like them just a little higher, just under shoulder height I am thinking. I was looking at a few T bars with a 10" rise 10" seems to be right where I would want them. The west coast bars I was looking at are 31" wide with 8" risers and 2" rise in the bars for a total of 10", How do I figure out clutch and throttle cable lengths, +4 or +6 would be my guess. Do I replace both upper and lower brake cables or just upper? From the other topics on this forum it sounds like there may be enough electric cable tucked under the tank.
Any help would be appreciated.
The best way I found to figure this out was to compare street Bob stock lengths vs FXDF, knowing that a stock FXDB cable setup will handle 12" t's. Measurements can all be found on Barrett's site. So if you wanted 10" t's go to street Bob stock length -2.
http://www.barnettclutches.com/1541/...dson-fxdb.html
I got plus +6 for my 14 fatbob, (magnum cables braided black) and I have 10" wild one t-bars and there is plenty of slack, maybe too much, however I don't mind this as i may go up to 12" one day.
Also, i my case the stock wiring harness was long enough stock, I didn't need to extend it at all.
I did +6 all around. Keep in mind that the lower harness for the brake lines stays the same length (as wheel travel didn't change) just the top part is lengthened 6 inches.
Also the stock HD brake lowers don't work with aftermarket brake lines as they are a single piece (upper and lower), whereas the aftermarket (at least the Magnum cables I got) were 2 pieces.
Lastly, keep in mind that if you have ABS then the lowers are much more pricey.
Here is what you need to purchase:
Clutch Cable
Throttle Cable
Idle Cable
Upper Brake Assembly
Lower Brake assembly
I got mine from Magnum Sheilding. here is a direct link for your bike:
https://www.magnumshielding.com/inde...3&color_id=any
On the upper left hand side you can narrow down the search by color if you like.
I hope that helps. I was new to harley when I learned all this stuff so I had to figure it all out myself (I wasn't a forum member then)
Clutch Cable
Throttle Cable
Idle Cable
Clutch Cable
Throttle Cable
Idle Cable
Clutch Cable
Throttle Cable
Idle Cable
Clutch Cable
Throttle Cable
Idle Cable
Clutch Cable
Throttle Cable
Idle Cable
