lowering front end on a dyna
Old 02-06-2016, 10:01 PM
Backwoods64's Avatar
Backwoods64
Backwoods64 is offline
6th Gear
Default lowering front end on a dyna
has anyone lowered there late model dyna by sliding the fork tubes up through the top tree a little higher than the stock setting? I assume this would change the trail somewhat??
Old 02-06-2016, 10:12 PM
Red Dragons's Avatar
Red Dragons
Red Dragons is offline
No, but that is certainly an option. Wouldn't do it more than an inch or so.
Old 02-06-2016, 10:19 PM
Backwoods64
6th Gear
thats kind of what I was thinking. just wanted to lower the stance a hair without effecting the handling. probably just have to do it and do some test runs?
Old 02-06-2016, 10:51 PM
Hephaestus's Avatar
Hephaestus
Hephaestus is offline
Yes it does affect the geometry of bike but moving them 1/4 to half inch wont be noticeable much. More than that and you will probably notice it while turning the bike.
I would put them where you want then ride the bugger. You can always loosen the triple clamps and put em back down if you dont like how it is!
Old 02-07-2016, 05:05 AM
Warp Factor's Avatar
Warp Factor
Warp Factor is offline
I have (on a Wideglide) and couldn't tell the difference in handling. The geometry change will be the same as lowering by putting in shorter springs, just a lot less work and expense, and you get to keep your full suspension travel.
Rockinronnie
04-02-2014 08:47 AM
CobraEd
07-23-2012 01:25 PM
timestarved
03-22-2011 05:39 AM
Devils Undies
07-14-2008 01:42 AM
DGlide04
11-24-2006 10:45 PM
Quick Reply: lowering front end on a dyna
