Street bob fender swap info needed
Looking at the part numbers and based on HD logic (the -XX in the part number is the last year it was last updated), if you have the circuit board already in the light housing you should be good, it was last updated in 1999. And the harness 68770-02B was last updated in 2002. So you should only need the harness to go from the seat to the tail light. Also, you might have to rewire or rebuild you turn sigs connectors because they will be going into the light housing for power and not under the seat. You'll have the harness going from under the seat to the main tail light and the sigs branch out from there. Not sure if removing the STT module under the seat will make a difference (if you have one, not sure if the canbus system uses one), removing it might only make your sigs just sigs and not additional run and brake lights.
Hey Gartec,
I realize this is a bit of an older thread. Did you ever get this all buttoned up? I'm doing this to a '15 Street Bob and I've got a fender on the way and want to go ahead and start ordering parts. Did you run into any problems? Did the dealer have to reprogram the BCM? Does anyone know of a curved license plate frame to go with the Kuryakyn Laydown Curved Mount? Or does it come with a frame? Thank-you!
