dual disc swap
Old 02-09-2016, 05:42 AM
superglidebob's Avatar
superglidebob
superglidebob is offline
Default dual disc swap
Looking for advice . I have a 2005 fxdi superglide I want to convert to dual disc . I already have the dual disc master cylinder. I found a good deal on a 1997 fxdl lowrider front end complete . will that bolt right on ? if not can i leave my trees and just swap the forks? thank you in advance Superglidebob.
Old 02-09-2016, 11:50 AM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,236 Likes on 1,812 Posts
Originally Posted by superglidebob
I found a good deal on a 1997 fxdl lowrider front end complete. will that bolt right on ? if not can i leave my trees and just swap the forks? thank you in advance Superglidebob.
How complete?... 1997 Tube\Slider Assy, Calipers, Rotors, Wheel, Axle?
They're all different from your 2005 FXD and won't directly interchange. You can work around some of that if needed. But you would be going backward on the brakes (1999-eariler Single Piston Floating Cals vs. 2000-later 4-piston Cals), although it would be Dual vs. your Single
Since your 2005 has a 1" axle & 39mm Tubes, if you found sliders from a 2008-later (has 25mm axle) Sportster dual disc model (883R, 1200R), they would be a direct interchange. You can use 2000-07 Sportys, but you would have to change your axle and bearings to 3/4".
Now if you could find some 2000-later Adjustable forks...You'd really be "Sittin' Purdy"
Old 02-09-2016, 12:07 PM
superglidebob
Thank you I have had trouble finding answers. I appreciate your time you gave me a lot of information to use.
Old 02-09-2016, 12:10 PM
superglidebob
also it is a complete front end triple trees down to the ground
johnod
EVO
20
02-19-2015 03:32 PM
RunswScissors
02-18-2015 05:57 AM
Vt harleydyna2003
09-28-2014 05:48 PM
Hoblick
10-20-2011 12:13 PM
hawg03
06-02-2007 10:59 PM
Quick Reply: dual disc swap
