How High can you Rev your TC Motor?
Old 03-06-2016, 08:27 PM
LunaticFringe's Avatar
LunaticFringe
LunaticFringe is offline
Default How High can you Rev your TC Motor?
I was just curious, for comparison, my stock tc88 tops out about 4,200 rpm before power drops off big time. I'm not sure why but I've never reved it over 4k, it's almost like the bike won't do it.
I've thought I've read about folks shifting at 5500 or even 7,000, is this true?
Old 03-06-2016, 08:31 PM
AdamM's Avatar
AdamM
AdamM is offline
My rev limiter is set to 6500 and its not uncommon for me to hit it.
Old 03-06-2016, 09:04 PM
IdahoHacker's Avatar
IdahoHacker
IdahoHacker is offline
Received 2,953 Likes on 1,685 Posts
Mine pulls like crazy to 6,000.
Old 03-06-2016, 09:24 PM
robbyville's Avatar
robbyville
robbyville is offline
Mine is set for 6200 and kept climbing but I haven't set it higher yet (nor do I really ever go there)
Old 03-06-2016, 09:46 PM
archergodwin's Avatar
archergodwin
archergodwin is offline
Stock bike? .. rev limiter. Most tuners will let you set that differently.
Old 03-06-2016, 10:01 PM
CJD197's Avatar
CJD197
CJD197 is offline
Don't forget the TC's were made with at least a couple different strokes. Longer strokes are more low end torque motors, while short strokes like to rev higher. It sounds like you have one of the long stroke motors.
Old 03-06-2016, 11:14 PM
HD Bobber's Avatar
HD Bobber
HD Bobber is offline
My limiter is set at 6,200 and when I dynoed I set it at 6,800.
Old 03-06-2016, 11:56 PM
fxdlx's Avatar
fxdlx
fxdlx is offline
He's got a TC88. That'd be 4" only I believe.
Old 03-07-2016, 06:02 AM
HarleyBob52's Avatar
HarleyBob52
HarleyBob52 is online now
My TC88 has no problem pulling strong to 5000 to 5500 rpm,, haven't took it any higher. Heck 4200 is normal shifting point if I want to "get on it" a little bit ... all stock except for AC and pipes
Old 03-07-2016, 06:11 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
OEM 88" with a pipe/air filter will run out of steam about 5500, and even by then, they are only slowing building power from around the late 4000's.
Cams, cylinder heads, intake, exhaust, compression, tune, change that.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Quick Reply: How High can you Rev your TC Motor?
