2007 HD Low Rider Idiot Gauge Cluster
Hello.... I had to move my instrument gauge cluster due to the fact I got bar riders. Im hooking up new LED lights on tank. Does anyone know what the colored wires wire to? I have attached a picture. Left and right turn signal and oil pressure, high beams and neutral. Hope someone can help.
The wires and the letters next to them:
Brown wire:R
Green and yellow:O
Light brown wire:N
Black wire:G
Orange wire:B
White wire:H
Purple wire:L
Thanks
Brown wire:R
Green and yellow:O
Light brown wire:N
Black wire:G
Orange wire:B
White wire:H
Purple wire:L
Thanks
The purple, brown, and white wires are switched hot wires for left, right, and high beam lights. The black is their common ground wire.
The orange wire is hot from the ignition. It's always on when the key is on.
The green with yellow, and the tan wire are switched ground wires for oil and neutral lights.
Your one black ground wire goes to the ground side of the right, left, and high beam. All three into one.
The oil and neutral will be opposite. The led positive will both connect to the Orange hot wire. Then the led negatives will go to their respective trigger wires. These to lights are grounded to turn on. The other 3 are given juice on the hot side to turn on.
dvsardina@gmail.com
06-26-2017 08:29 AM
dvsardina@gmail.com
Electrical/Lighting/Alarm
06-26-2017 08:27 AM
