Help with tank removal - turn signal relo
Well not really removal, but slide back. I'm doing the turn signal relocation kit on my FXDL today. It's the first real work I've done on my bike so I am new to working on it. I have the service manual. First step is purging the high pressure fuel line and disconnecting the line in prep for unbolting and sliding it back.
It seems pretty straight forward but when I disconnect the fuel line, is all the gas going flow out of the tank or just whats left in the line. Prior steps are to disconnect the fuel pump module from the tank plate and start the engine until it stalls. Then hit the starter for 3 more seconds after the bike stalls.
Also the relo instructions say to remove main fuse, service manual says remove the negative battery cable. Does it matter which one I do?
Twospot (03-19-2016)
robbyville (03-19-2016)
Hmm, looks like the MoCo changed the purge system on the newer bikes. On my '010, I pull out the fuel pump fuse first, then start the motor and let it run until it stops after a couple of seconds, then crank the motor a couple of more times. The main fuel line can then be disconnected with hardly any spillage.
However, when you disconnect/cut the crossover line at the front of the tank, any fuel that is in the tank will come pouring out. Best to siphon gas out of the tank first before removing the crossover line.
But as suggested above, after you pop off the main fuel line, slide the tank back to see if you can access the wiring harness in the frame hole before messing with the crossover line. Hope it works for you.
Forgive me if I'm just screwing everything up here but isn't the fuel pump connector kind of inside the tank?
