J&S Motorcycle Lift... Why Didn't I Do This Sooner?
I had a 2004 FXD, and when using the Sears Yellow Jack, I was told you had to also use the Harley Davidson adapter blocks to prevent lifting stress on the transmission. I now have a 2015 Dyna Low rider. Are the Harley Davidson adaptor blocks needed with the J&S lift? Thanks MONDOMAN
My dyna is an 08 FXDWG stock height, has not been lowered. With the bike on the sidestand it slides under with plenty of clearance.
I position my jack so that the front lift arm slides under just in front of the sidestand this lets the rear lift arm clear the frame guard on the right side of the bike. Once the jack is under the bike you never have to touch or hold the bike, once you start cranking the jack up the bike lifts off the sidestand and settles perfect on the jack. Going down I just slightly crack the valve on the jack and let it come down slowly to rest itself on the sidestand, again you never feel like you have to touch or hold the bike
This is a couple more shots that I took yesterday, it may help everyone see how this lift fits under the Dyna. No adapter blocks, it slides right under my '13 Wide Glide with no problems. It's correctly designed to work with the Dyna, tucks right in and even misses the jiffy stand bumper
And Mxdad is right on the money, the only negative about this lift is I waited so long to buy it! Oh, there is actually another negative. Now I can finally see under the bike and my OCD has kicked in; she's not as clean as I thought
Mxdad (03-24-2016)
