I have a 2004 Dyna with a stock 88 and 5 speed.
Will a 2007 96 cu in bolt in with my existing 5 speed?
Any changes to the 96 engine case that may affect bolt in?
Jim
Thanks and grateful for your help.
On that case, would the complete 2007 96 cu in engine with matching 6 speed transmission
bolt into my 2004 frame?
Jim
If you're wanting some more fun when you twist your wrist, you might do just as well, to put a 95" big bore kit, and a little headwork... will more than keep up with a stock 96.
yes it will if you buy the whole drive train, just tonight put a 2008 flhx motor trans and primary in to a 2005 road glide will bolt right in.
there are things to over come, regulator plug, speed sensor ect.... but nothing big
cant tell me i got the only 2005 96 inch stock 6 speed lol
For a bagger frame, you'll have to use a later model left swing arm bracket to clear the primary.. Too bad you are giving up the 5 speed.. Much better than the 6..
While the motor is the same, the tranny and primary cases are still different between baggers and Dynas.
Why is the swingarm needed?
I agree with keeping the 88 ci motor / drive train.. Better tranny, better compensator, less load on the inner primary bearing.. Better primary chain tensioner. Only things worse are starter replacement is harder and old style cam chain tensioners.
