23" front wheel on a 2009 street bob Help!
alright so I'm turning my dyna into a bagger. whether you like it or not, I need some help please. after much reading I decided to go with a 23x3.5 front wheel for my build. a few people posted info and pics of that size wheel on a mid glide front end. mine is here and it doesn't fit! It just barely fits without the rotor bolted on but you bolt the rotor on and the rotor bolt heads hit the fork and its just to wide. seems as though my only option is to go with wide glide triple trees? its an ultima king fat spoke wheel. I guess the hub is to wide?
has anyone done the wide glide tree conversion? will it bolt right onto my 2009 street bob? will my stock fork lowers clamp right back into the wide glide trees? this bike has already blown the budget and this was a let down. thanks for any help.
hey dyna bagger! ive read a lot of your posts and gotten a lot of info from you. thanks for everything. I will buy wide glide upper and lower trees, and an axle. my stock tree bearings should work right? and you think the stock spacers will work?
also the big question... why did you go back to stock setup?
I went back to mid glide because I just felt like I was building the wrong bike.
Oh i gotcha. Going in a different direction or staying stock? Prices for a bagger around here are crazy. That's why I'm trying to build one. Although this is going way over budget now and I'm kind of regretting it. I already ordered everything for the swap. Top tree, bottom tree, axle, handlebar mounts, and bushings. Is it hard to swap out the triples and swap bearings? Any tips?
Hi Mike. I've read your whole tread and I got a lot of info from your build. I ordered wide glide upper and lower trees. I want to do the lower leg swap so bad but I'm already way over budget but next winter it's happening! Do you know how wide center to center your forks are at the clamps now? Also how wide are you from fender mounting holes? My parts are on order so I'll know in a few days anyway. Your bikes looking great
