Front brake line change...
Hey guys,
I changed out my bars and now need to run a new brake line a little longer. Can anyone help me out who has done this?
I bought a Magnum 48 inch line where the length is perfect. The issue is my bottom banjo fitting is 10mm or 3/8 and the upper master cylinder banjo fitting is 12mm. I though that both were 10mm, but I was obviously incorrect. Has anyone else changed out the brake line like this and ran into the same issue? Can you verify this is how yours is setup? I have been trying to do some research and cant find any documentation anywhere showing the size of each banjo fitting from OEM.
Thanks!
Thanks!
Received 2,189 Likes
did you test fit you existing hardware? the sizes on M/C and caliper is not going to change banjo wise. the head size may change, if some were supplied with the line
https://www.hdforums.com/forum/dyna-...l#post14791267
my dyna had 12 point heads, i reused them. saved the new s/s stuff.
cvaria (05-02-2016)
steveh326
04-19-2015 06:02 PM
BigBearBiker
06-28-2005 02:03 AM
