Not to beat a dead horse.... Or a cow in this instance.
Hello all new to the forum. I have a couple of questions.
I just inherited my father inlaws wide glide. Its a couple states away and i decided id ride it back. Here the dilema. He was a short man. 5'8". And im 6'6" and 300 lbs. and a 35 in inseam.
currently installed are some 16-18 in apes and a seat that puts you up on the tank.
I would like a seat that is down and back from stock which given the seat on it now should give me 6 inches or more leg room. I need a seat i can ride all day on. And the wife has requested a comfy seat for her as well.
Im looking at the danny gray weekday 2-up xl. Thoughts comments questions or any advice please.
Also wanna swap the apes for fat drag bars any help with what's involved and parts needed would be greatly appreciated as ill be flying in swapping parts and riding out to return home someday lol.
Thank you
Thank you
What year is your FXDWG? Mine is a 2010, which is the first year after they redesigned that model. It sits rather low. I'm 5'5" and have no trouble sitting on the seat and having my feet flat on the ground.
The Mustang seat makes me sit higher up. It's not really back all that much farther just higher.
Does yours have the stock seat or an aftermarket reduced reach seat?
Do you have photos?
Some dealerships have "test" seats that you can put on your bike to try out. You might check and see if a dealership near where the bike is located has this option.
I just noticed that you've only got 2 posts, I think you have to have either 5 or 10 posts before you're allowed to post photos so that's not going to be helpful.
Do you have photos?
Do you have photos?
Do you have photos?
I already know i need forward control extenders.
OK, that bike is a different design than what I have. It's probably got a reduced reach seat. Check with the dealerships near where the bike is and see if they have test seats. Seats aren't cheap and are non-returnable so you want to make sure what you're buying is really what you want.
Also if you're going from Apes to drag bars that is going to change the position of your body in the seat so when you sit on the test seat make sure to lean forward as though you've already got those drag bars on it.
just my 02 cents
if your going from apes to drag bars your screwed from the get go. your 6'6 and with drag bars and and a goose down feather seat you wont go more than 150 miles without your back screaming. you will be reaching forward. stay with the apes, it's the simplest way for you to fit on the bike.
