Dyna Air Baffle/Wind Deflector
It's an issue with windshields, air moving over the top and bottom mix at a certain spot create a turbulence at higher speeds, (usually 40mph and up) behind the windshield. It can make a nasty vibration around the riders head. If he's wearing a helmet it can really shake your head around .
Blocking air from underneath, sides or creating an air flow mid point in the windshield changes where that turbulence occurs.
The term "Buffeting" is usually used when a riders helmet is rocking around.
The 18" quick detach windshield the previous owner bought creates helmet buffeting so bad I can see straight anytime after 50mph,, If I crouch down I don't get it,, but who want's to ride like that,, the Quick detach is "detached".
Just hoping that the baffle isn't too far from the bottom triple tree. As you can see there's a gap on each side. Didn't want it too close cutting into the brake line. Couldn't find any good pics online but hoping this is how people did it on the Dyna's. Now if I can just find the time to ride it and test it out...
I will post results next week after my trip to Oregon. Should be hitting rain. I run an 18" rifle roadster fairing and while the upwind to the chin isn't unbearable I'd like to cut it down or eliminate it completely on long rides to help with fatigue.
Don't have the problem with my beard cause I usually always wear a full face. But the full face catches more wind which is one of the drawbacks.
By the way, nice burn out!
