Getting a low rider
Getting a low rider
Hey everyone. I'm currently visiting my father in law in Colorado Springs and he just told me he wants to buy me a new bike before we leave and I'll ride it back. His reasoning is that I've had my Suzuki Volusia for coming up on 10 years and he wants me on something newer. Though the Suzi has been a great bike and super reliable!!
Anyways I'm looking at getting the Low Rider S this Friday and riding it back to San Diego on Monday. My question is the initial service. Seems like it is a 1000 mile requirement. The trip is 1100 miles. Think I'll be ok to have it done once I get back to SD? Or is this one that the motor company is adamant about having done on time?
I will, just like to get others opinions and see if anyone else has done the exact same thing.
I can tell you that 3500 rpm in 5th gear will get you 80 mph. And once you click over 500 miles, you can drop it into 6th and use the cruise control. Just vary the speed a lot until you get to the 500 mile mark. There are Harley Dealers along your route so maybe take that into account as you plan your trip back and if you have any issues, keep their numbers handy in case.
If you are in San Diego and want to purchase that bike from Colorado, you better check the $350 part you need to be California emissions compliant. You might not be able to register that bike in California. If you do get it and there are no issues, make sure you do not keep the same RPM on the motorcycle for more than 10 miles at a time. Drop the RPM and get it back up every 10 minutes. It is a part of the break in on these bikes and it really does make a difference for wear, stretching out new parts etc. The 1,000 mile service is basically tightening all the parts back to spec after "WEARING them in" Good luck on the trip too. Im headed back to my home town in Ventura Thursday. Need to be there Friday by noon.
OP, I reckon you'll be fine. Just run it up and down through the gears and the RPM range a bunch of times, mainly the first twenty miles, if you're worried. Honestly though, metallurgy and engine design, and factory setup practices, have come far enough that a stock Harley engine is pretty much broken in by the time you get it. The components haven't worn into each other as much as they will have when you hit 1k, that's why the first oil change is so early, but apart from that, you're golden.
Yup... You will defiantly have registration problems with a bike that has under 8000 miles on it. If I remember correctly, you can't bring in anything under 8000 miles unless you yourself are moving into the state. Even then, the smog impact fees ( I believe that's what they call them) will be a good chance of change.
You may be able to have all of the Ca emissions equipment added to the bike, but I am sure it'll cost you.
I would contact the Ca DMV and explain the situation before you do this. Maybe he can buy it for you once you get back to San Diego.
