Brake pad question FXDL
So lately my rear brake just doesn't seem right. I seem to really have to press pretty hard to get some response. Without taking them off, they seem to have decent pad left (only 9000 miles). I went ahead and took the caliper off to really get a look. I loosened the pad pin then removed the slider pin and mounting bolt and pulled the caliper off the disc. If I didn't leave the pad pin in loosely threaded, the pads would have just fallen out on to the ground. Is this normal, or should the pads have been secured in some how? It's a 2015 model.
I did check the reservoir but I do not see any fill line to gauge if it's low. I also do not see any fluid leaking anywhere, which is why I am checking the pads.
Normal; the tabs on the front of the brake pads slide on each side of the silver torque clip and in to the notch on the caliper bracket when you install them. I'm sure you've already figured it out but be certain you use a 12 point socket or wrench on the pad pin; a 1/4" will cheat on HD's metric pad pin nicely
The rears are rather ineffective with only 2 pistons on one side, the inner pad sort of hangs out so the pads will wear unevenly with the outer/piston side pad wearing quicker. I've had better results with the rear brake using Lyndall #7257 Z+ and Gold+ pads and keeping the fluid fresh but your front brake is your primary weapon
The only real solution on the HD rear brake is to keep your master bled and the fluid fresh and swap out the pads; I think of the rear pads not in miles but rather in time. I do practice slow speed motor officer parking lot exercises slightly dragging the rear; I also practice threshold braking, and I'm an absolute trail braker in the corners so I just see those rears as the price of doing business and change them out and bleed and flush the fluid the moment I notice a diminishing return on the rear brake.
Luckily Lyndall Z+ pads are inexpensive and work amazingly better than the OEM pads
Twospot (06-01-2016)
Received 5,373 Likes
Here's where I've been getting my Lyndall Z+ #7257 rear brake pads. $41.76 shipped, Amazon and Powersport Superstore for the win!
Edit: Forgot to mention, the front pads are #7256 when you want to change them out...
BigDogIdaho (06-02-2016)
