Lowrider S vs Streetbob Rake Difference
Old 06-09-2016, 06:57 PM
Shaved Ice's Avatar
Shaved Ice
Shaved Ice is offline
Default Lowrider S vs Streetbob Rake Difference
The HD website says the Lowrider and Lowrider S rake is 30.5 degrees at the steering head. The site also says the Streetbob rake is 29 degrees at the steering head. Is this the only difference in overall rake or do the bikes have different triple trees?
I ask because I am considering putting Streetbob triple trees on my Lowrider S to decrease / improve trail. A forum member told be the forks were the same length for both model numbers. Can anyone confirm or deny?
Thanks in advance.
Old 06-09-2016, 07:39 PM
craigffb's Avatar
craigffb
craigffb is offline
Old 06-09-2016, 08:45 PM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,236 Likes on 1,812 Posts
Thanks in advance.
Same 29° Frame
Sbob 0° Trees
LR 1.5° Trees
If you keep everything the same on your LR except for adding the 0° Sbob Trees (decreasing tree rake)...you will INCREASE your trail
Looks like the Tubes are same length (same # non cartridge side)
Old 06-10-2016, 06:25 PM
Shaved Ice's Avatar
Shaved Ice
I am confused. Someone needs to break this down for me more I guess. My Lowrider S has the same size tires and same height rear shocks as a Streetbob. If I change the triple tree to a Streetbob triple tree (and you say the forks are the same) then my trail should be exactly the same as a Streetbob in my mind.
The HD site says the trail of a Streetbob is 4.7 and the trail of a Lowrider S is 5.1. How is your math calculating that adding Streetbob triple trees will increase my trail?
Anyone else care to chime in?
Old 06-10-2016, 08:16 PM
multihdrdr's Avatar
multihdrdr
You need math to arrive at a value...You don't need math to know how changing the Rake affects Trail (increases or decreases).
After your statement..."I am considering putting Streetbob triple trees on my Lowrider S to decrease / improve trail"
You were basically saying "I'm considering putting triple trees with less rake to decrease trail"...I was just trying to get you back on track.
TREE RAKE
Take any given bike and ONLY add Trees with LESS Rake ...Trail INCREASES
Take any given bike and ONLY add Trees with MORE Rake ...Trail DECREASES
Btw, Neck Rake and Tree Rake affects Trail in opposite directions
NECK RAKE
Add LESS Rake to the Neck ...Trail DECREASES
Add MORE Rake
to the Neck ...Trail INCREASES
Old 06-10-2016, 08:36 PM
Mchad's Avatar
Mchad
Mchad is offline
Received 3,510 Likes on 2,133 Posts
Does a third of an inch make any noticible difference?
Old 06-10-2016, 08:51 PM
multihdrdr's Avatar
multihdrdr
Here's a calculator to prove the Theory to yourself...Values are for comparison
"ONLY add Trees with LESS Rake ...Trail INCREASES"
Hope it helps
https://www.rbracing-rsr.com/rakeandtrail.html
The following 2 users liked this post by multihdrdr:
1SG_Chuck (08-29-2020), Shaved Ice (04-01-2017)
Old 06-10-2016, 09:10 PM
Maxxsmart's Avatar
Maxxsmart
Maxxsmart is offline
In short, yes, the S, and standard DL have different trees then a FXDB. The pinch bolts on the DB are parallel to the wheel, where as the lowrider has them at an angle.
Old 06-10-2016, 09:21 PM
multihdrdr's Avatar
multihdrdr
More importantly...they have different rakes. Unless you were just adding some visual cues
Old 06-10-2016, 10:09 PM
Maxxsmart's Avatar
Maxxsmart
Previous post asked if the trees were different. I was simply pointing out that in fact, they are different trees. Given the listed variance in rake, I just assumed the trees would be the source.
Quick Reply: Lowrider S vs Streetbob Rake Difference
