Low Rider S tach
Low Rider S tach
I assume all owners of the new Low Rider S that try to look down at your tach while accelerating are wondering if there is a better setup for this performance focused bike - Same here.
Does any of the other speedo/tach setups fit on the Low Rider like the Wide Glide which has the integrated tach in the speedo. I don't know what the name of the tank strip is called, but it isn't that appealing or functional.
any suggestions?
any suggestions?
I wear a FF helmet and it's not easy to even look at the tack so I don't bother. I would have preferred the old Mickey Mouse ears set up a tach and speedo on the handle bar.
But I rate it as a very minor issue. I get the feel and sound of the engine and a tach is just a distraction with little use. Now a shift light is a better idea.
