What issues can you have with a spoked bike?
Regular maintenance including lifting and checking the spokes with a spoke torque wrench.
Start with marking every fourth one with a piece of painters tape, check torque around half spec every fourth then third then second, last check full 55 inch pounds same rotation.
Mostly the front wheel will go out taking the blunt of road punishment.
If you do the spoke wraps and need to pry slightly for the proper install be sure to recheck the torque.
As anything on a bike you need to keep up on it.
I'm curious. What's wrong with 40 spoke wheels? Going to 80 spokes significantly increases weight. They take longer to lace and true..
Received 2,189 Likes
Spokes have their place. I'm converting from mags to spokes on my WG. Fit the character of the bike better and it also allows me to reduce unsprung weight and get wide rims without spending kilobucks.
I did notice that my Buchanan stainless spokes called for a nipple torque of 80+ in-lbs versus the 40-50 in-lbs in the service manual. Not sure why that is, but I've had no issues whatsoever with my 40 spoked aluminum rear. I've got about 1000 miles on it now and have checked the spoke tension (by plinking) about every week since I built the wheel and nothing is budging. I haven't noticed any performance or handling or NVH changes since putting it on. Significantly more grip from the new tire, but that's it.
I did do a static balance of the wheel (weights inside, under the rim strip) prior to mounting the tire.
Received 47,744 Likes
cvaria (06-29-2016)
I've owned over 45 motorcycle and the majority of them were spokes (think the '60's and '70's). If you're old enough to remember, all bikes used to come with spokes. Of all those bikes, I've NEVER had any problems whatsoever with spoked wheels. None. I have a buddy with a 1999 Sportster Custom with a 21" spoked front wheel. He's never tightened, checked, or had problems with it. Never even had them checked. The bike is 17 years old, he recently replaced the front tire, and they said the front spokes were fine.
I did go look at the 2006 Dyna Low Rider at Jacox Harley in Mississauga.
I really liked the blue and silver, but it had about 73,000 kilometers on it.
The Wideglide is at a dealer on Kijii. The Low Rider is at a Harley dealer
in Hamilton. No I haven't gone to Hamilton yet nor the dealer on Kijiji,
but I'm not just a Harley dreamer. The photo is of my Harley I sold a
couple of years ago. I just can't make up my mind.
