What should I do while gas tank is removed?
Here it is: http://www.motionpro.com/product/12-0037
I actually discovered it in a post here in the forum somewhere...
Those are CPC quick connects. Colder Products Company. A competitor of the company I work for.
Those are the PMC series couplers.
http://www.cpcworldwide.com/Product-.../6?Category=44
Cut out Motion Pro and their markup if you want...won't hurt my feelings.
Example: https://www.amazon.com/gp/aw/d/B0025Q1OXE
No problem! They make a fine product. Gasoline isn't listed in their their normal applications and I didn't look up acetal compatibility, but it must be OK if Motion Pro is selling them as such.
Probably cheaper yet from some place like MSC, Grainger, or McMaster-Carr. I didn't check.
Those cast style breathers have been updated to a stamped sheet metal style. If you go that route, MAKE SURE you get the correct bolts to go with them. The correct bolts are shorter, using your original bolts with the new breathers can crack your heads.
Also be sure to blow out any oil from any bolt holes. The oil in those holes will have nowhere to go when the bolt is tightened and again.... head damage.
For ROCKOUT information & purchasing please click the LINKS below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
