Use loctite on exhaust bracket/tranny cover bolts?
Old 07-27-2016, 10:04 AM
Mchad's Avatar
Mchad
Mchad is offline
Received 3,510 Likes on 2,133 Posts
Default Use loctite on exhaust bracket/tranny cover bolts?
I have to fiddle with my exhaust and I need to remove one of the two muffler bracket bolts so I can swing the bracket down.
My question is should I put blue on the bolt when I torque it down? The manual doesn't say so, and it usually does when required. But I've seen instances where it doesn't...
Just wondering. Tx.
Old 07-27-2016, 10:50 AM
TinCupChalice's Avatar
TinCupChalice
TinCupChalice is offline
Received 8,749 Likes on 3,962 Posts
I've never used loctite on the exhaust mounting bolts, just correct torque. I do put a bit of anti-seize on the bolts and as the anti-seize is a lubricant I reduce the torque spec by 15%. So far, never had one come loose or be over-torqued ::: knock on wood :::
Old 07-27-2016, 11:24 AM
raywj's Avatar
raywj
raywj is offline
Same here, no loctite on exhaust stuff...just torque. However, blue loctite couldn't hurt. If it makes YOU feel better do it.
Old 07-27-2016, 11:36 AM
JohnMn's Avatar
JohnMn
JohnMn is offline
Mchad is referring to the transmission side cover bolts,, V&H uses two lower bolts to hold the after market exhaust bracket.
That said;
I did. Matter of fact I changed the trany side cover and cam cover to chrome this last spring and used a a little blue on all the bolts for both covers.
Old 07-27-2016, 12:05 PM
raywj's Avatar
raywj
raywj is offline
I didn't use loctite on those either 😬
Old 07-27-2016, 12:07 PM
DynaKid94's Avatar
DynaKid94
DynaKid94 is offline
like the commercials for that frank's red hot sauce - i put that s**t on everything...could be completely unnecessary, but loctite is relatively cheap...lol
Old 07-27-2016, 12:16 PM
Mchad's Avatar
Mchad
Mchad is offline
That said;
Yes, this exactly.
So some do, some don't. Ok. Coin flip time!
Actually I pulled the bolts already, and the existing ones did not have any residue on them, so while I had the stick (I use the new Chapstick style loctite - very convenient!) I didn't this time.
I'll check them from time to time and if there's any loosening, on it'll go.
But thanks for the responses.
Old 07-27-2016, 12:17 PM
dmhines's Avatar
dmhines
dmhines is offline
Does anyone know what the white locking compound is called that the factory seems to put on every bolt ?
Old 07-27-2016, 12:20 PM
Uncle Larry's Avatar
Uncle Larry
Uncle Larry is offline
Received 47,780 Likes on 18,557 Posts
Caucasian ??
Old 07-27-2016, 12:25 PM
TinCupChalice
That said;
Oh, I know exactly what bolts Mchad was asking about; the 9/16" bolts used to secure the exhaust mounting bracket to the rear of the transmission case.
To the left in this image; covered with chrome cap covers secured with silicone I doubt it matters if you use blue loctite or do nothing but anti-seize; correct torque is the key to it...
Quick Reply: Use loctite on exhaust bracket/tranny cover bolts?
