Project Rushmore Dyna
Old 08-09-2016, 10:20 PM
traffic jam's Avatar
traffic jam
traffic jam is offline
It looks amazing. I think it looks better than a SG!
Bobby12012 (08-11-2016)
Old 08-09-2016, 10:56 PM
blueangel73's Avatar
blueangel73
blueangel73 is offline
Damn you Bobby, just when I think I have found the sweet spot, you go and show me I can take it up another notch. Now to start looking for parts and getting ready for the winter.
Other than adding the drop kit to the front end, did you do anything to help with the quality and performance of the front suspension do to the added weight?
Also, I like to see how you have the exhaust mounted to the bag supports, I have been wanting to go the true dual route for a while now, just couldn't think of a way to hang them.
Old 08-09-2016, 11:19 PM
EricInNCa's Avatar
EricInNCa
EricInNCa is offline
Wow! That really turned out Great! Nice attention to detail.
I'm thinking you should hang on to that one! Buy another project bike...
Old 08-10-2016, 04:18 AM
Bobby12012's Avatar
Bobby12012
Bobby12012 is offline
Blue angel ... Other than the progressive lowering springs , I did move up to the screaming eagle fork oil for the heavier weight .. Didn't figure there would be an issue considering up to 2014 all the naggers had a 41mm fork anyway .. Those 49's are pretty beefy !
As far as the muffler mounts , I tried to get ya some pics this am but it's all black on black on black , ya can't see **** I'm them . I drew ya a couple rough sketches to show where I positioned the mounts .. The "how I did it " installed pipes and slid muffler on , supported muffler with bike jack ,put rubber grommet in support block and attached to muffler . I then slid it back till it made contact with my rails . Small tack weld on top then unbolted from muffler , pulled out grommet , remove rails .. I then ran a full bead on both top and bottom, painted, and reinstalled
As you can see here , it isn't traditionally centered under rail due to the location of the mounting points on mufflers . It is just the top edge touching the bottom edge of rail which is why I kinda went overkill on the weld
Old 08-10-2016, 04:39 AM
Ron750's Avatar
Ron750
Ron750 is offline
Received 16,515 Likes on 6,271 Posts
Wow. Gorgeous bike. And definitely not cookie cutter. Way cooler.
Old 08-10-2016, 06:17 AM
1HD1C's Avatar
1HD1C
1HD1C is offline
Great job!!!!
Old 08-10-2016, 07:25 AM
rauchman's Avatar
rauchman
rauchman is offline
Received 3,234 Likes on 1,254 Posts
Wow. Excellent job! Really really nice setup. The satisfaction of creating that must be off the charts. Congratulations on a first rate job.
Old 08-10-2016, 08:59 AM
chino_1219's Avatar
chino_1219
chino_1219 is offline
That, my friend, has been done really nicely!!!! Did you notch the hard bags to get it to fit around the shock like blueangel has done? How are the bag supports mounted? I am in awe of the work done, and looks like it rolled off the showroom floor like that.
Old 08-10-2016, 10:00 AM
misfitJason's Avatar
misfitJason
misfitJason is online now
Received 1,028 Likes on 651 Posts
I'll be honest. It's not my cup of tea but I am in awe and impressed by the amount of work that went into that and the cleanliness of how it turned out.
Old 08-10-2016, 10:21 AM
Bobby12012's Avatar
Bobby12012
I did notch the bags .. The brackets are the cycle visions bagger tail brackets
Thanks for the compliment
Quick Reply: Project Rushmore Dyna
